Runing like a cammed big block
Old Oct 10, 2005 | 09:19 PM
BuickTurbo's Avatar
BuickTurbo
Ever seen this before?
I have no codes.
New Fuel Filter, oil change.
This just started happening today. The truck has not been drivin in 3 days. Now after 15 - 20 miles of driving it starts lobing. When I come to a stoplight the truck is surging forward while idling like a 208/210 cam in a big block. Maybe two revs per second. After a minute or so, it will slowly come back to idle at 720-750. Anybody?? I am going to call Edge to see if they have seen this.
Old Oct 10, 2005 | 09:40 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Same oil you always use, or something different?
Old Oct 11, 2005 | 08:14 AM
BuickTurbo's Avatar
BuickTurbo
No, same oil. Seems like a fuel problem. I don't think my "water in fuel" light is even on my speedo face. I'm going to check that today. I suspect the fuel, fuel pump, cam sensor or TPS. When it starts doing the wierd thing, I put it in neutral and it slowly goes away back to a regular idle. The truck is also idling at 1050 every once and a while. Otherwise she runs fine.
Old Oct 11, 2005 | 08:29 AM
Kwikkordead's Avatar
Kwikkordead
How about a failing HPOP pressure sensor? Making the pressure shoot way up. Your symtoms describe the rough idle of a 5.6k mod only exaggerated.
Old Oct 11, 2005 | 09:26 AM
Fordafied's Avatar
Fordafied
I "think" it will be in your tuner. If I start my truck in program #2 it will do the same thing. It will lope like hell; it goes from 500rpms to 1000rpms very quick. Just like a huge cam would do. It goes away as soon as I flip to another setting. If I switch it back to #2 it is not there. Setting # 2 on my flip chip is the stock setting. I know we are talking about 2 different programmers, but mine does the same thing. My 8 year old loves it.
Old Oct 11, 2005 | 10:22 AM
jesse460's Avatar
jesse460
Either scan it or put a gauge on the hpop, you might have a problem with your IPR. I have a buddy whos truck is doing the same thing, his ICP is at 1600 just Idling. does the truck sound louder and clatter more when idiling?
Old Oct 11, 2005 | 11:09 AM
No2Oil's Avatar
No2Oil
Wow, Buickturbo I have the same problem. I spoke to Jody and he said it's the IPR. What's your email address? I have a document from Jody on how to clean the IPR. I'm gonna do this today, I'll let you know if it fixed the problem.
Old Oct 11, 2005 | 12:33 PM
BuickTurbo's Avatar
BuickTurbo
HPOP = high pressure oil pump?
IPR = I have no clue.
Old Oct 11, 2005 | 12:52 PM
Kwikkordead
HPOP = high pressure oil pump? Yes.
IPR = Injector Pressure Regulator.
Old Oct 11, 2005 | 01:31 PM
BuickTurbo's Avatar
BuickTurbo
Either way, I believe that abreviations always cost a lot of mooooola.
SO what can I expect to happen as either of these problems progress?
What, other than complete part replacement, are better options? (aftermarket)
And when quoting prices on these items, will someone be prepared to hold and nurture me?
Old Oct 11, 2005 | 02:33 PM
SpringerPop's Avatar
SpringerPop
Have a look at:
http://cw-diesel.com/LuxSite/IPRInfo.htm
It details the cleaning of the IPR. You may just have some gunk in yours. Lack of regulation would cause the symptoms you describe.
Pop
