MAP sensor
Old Oct 9, 2005 | 09:30 AM
fordfinatic's Avatar
fordfinatic
MAP sensor
Just wondering if a bad map sensor would cause a 1986 ford f150 5.0 302 fuel injection, not to start Thanks
Old Oct 9, 2005 | 04:34 PM
Franklin2's Avatar
Franklin2
Do a code check and see what the computer says. If the computer is happy, look for more conventional stuff like fuel and spark.
Old Oct 9, 2005 | 04:40 PM
Dannym's Avatar
Dannym
If you have a meter that can count frequency (kinda rare) or an oscilloscope you can check the MAP sensor just by touching the right connector in the harness. You have to look at the altitude you're actually at first.
Old Oct 9, 2005 | 06:35 PM
peppermrj's Avatar
peppermrj
I doubt it. You can do a check of the electrical connection. Also check the vacuum line at the sensor for gunk. Also check the rest of the vacuum line and hose.
