How do you test for lower intake leak?????
Old Oct 7, 2005 | 07:52 PM
meck1's Avatar
meck1
On the EFI models, how can you test to see if the lower intake manifold is leaking, either at the gaskets or due to a crack in the manifold?
Thanks
Old Oct 7, 2005 | 09:04 PM
andym's Avatar
andym
Spray some carb cleaner around the contact surfaces. If the idle jumps up, you have a leak. The vacuum will suck the fluid in and combust like gas will.
