1978 - 1996 Big Bronco
Need help finding an EVR Valve
Old Oct 7, 2005 | 11:54 AM
Project:91Bronco's Avatar
Project:91Bronco
Dont think im crazy but i do not mean EGR. The EVR (Electronic Vacuum Regulator) controls how much vacuum is applied to the EGR valve. According to tests from a Hanes Manual, mine is bad. I've tried looking at Advance and other parts suppliers: no body has it! I even checked Ford's original Parts: no luck... Unless its called something else, i dont know where to find it other than a junk yard. Any body have any suggestions?
Old Oct 7, 2005 | 12:35 PM
twisted's Avatar
twisted
i would take a chance and call a parts yard.
Old Oct 7, 2005 | 01:28 PM
broncobillybob's Avatar
broncobillybob
yeah, I'd get several (if able) while I was at too. Because in theory anything from the parts yard could be in better, same or worse condition than what you have now. thats just what you deal with in parts yard parts.
Old Oct 7, 2005 | 04:13 PM
greystreak92's Avatar
greystreak92
The only number I could find on the one on my 93 was 3D27E. Its the OEM component as it has the FORD emblem embossed in the vent cap. You have the correct description according to every source that I could find. Try calling it the "EGR vacuum valve" My own mechanic wasn't sure what I meant until I told him what its supposed to do.
Old Oct 7, 2005 | 04:25 PM
ford390gashog's Avatar
ford390gashog
try www.motorcraft.com find the part number then buy from www.rockauto.com
