Front Axle Question
Old Oct 7, 2005 | 04:34 AM
romcjr's Avatar
romcjr
Question Front Axle Question
I have a 92 F350 4X4 7.3 E4OD built in Canada.Can anybody tell me if the front axle is a full locker or a limited slip.It has automatic locking hubs if that helps any.Thanks,Ron
Old Oct 7, 2005 | 04:54 AM
ford390gashog's Avatar
ford390gashog
open differential. unless changed at one time which i doubt.
Old Oct 7, 2005 | 12:05 PM
phoneman91's Avatar
phoneman91
Look at the driver's door jam Ford factory VIN/Bar Code sticker--under the "axle' category. If there is a three numeric/alpha code--and the last number is "2"--then you have a factory limited slip in the front differential.
For example: F52 would mean that you have a 8250 pound rated rear axle with 4.10 limited slip (F5) and a limited slip also in the front differential(2).
But unfortunately--the factory never installed front limited slips and automatic hubs together. Only manual hubs could have factory limited slips. And I believe--only 3.55 gears could have factory front limited slips.
Old Oct 7, 2005 | 12:11 PM
andym's Avatar
andym
I'll add that factory front LS axles are very, very, very rare.
