high idle control
Old Oct 6, 2005 | 08:27 PM
bunnycop's Avatar
bunnycop
high idle control
does any one know if there is a way to bring a 2006 5.4 liter idle up (1200rpm)while sitting still with a flip of a switch like on the PSD? what color wire should i look for, and where is it located?
Old Oct 6, 2005 | 09:21 PM
ford390gashog's Avatar
ford390gashog
not that i am aware of. whats the need for the high idle?
Old Oct 8, 2005 | 03:55 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I brought up the same question in the V10 forum, there appears to be no "high idle" circuit anywhere on the gas motors.
I believe the only option would be an aftermarket cable or solenoid-operated high-idle thingy (if they exist - but I'm sure someone makes one).
art k.
Old Oct 8, 2005 | 05:28 PM
bunnycop's Avatar
bunnycop
i thought there might be a way to do it with a wire and some resistors bing that the throttle is electronic now. i needed high idle because i have emergency equipt instaled and when i am on scene with all my lights on, there is a bigger load on the alternator
Old Oct 8, 2005 | 06:55 PM
ford390gashog
maybe a aftermarket throttle body? and set the rpm to 1,000 rpm.
tmiddleton57
Modular V8 (4.6L, 5.4L)
Oct 13, 2004 08:30 AM
meck1
Aug 2, 2004 10:04 AM
scroogetrades
Bronco II
Feb 26, 2003 09:44 PM
Hwy Apostle
1978 - 1996 Big Bronco
Oct 11, 2002 01:42 PM
rebocardo
Sep 30, 2002 06:53 AM
