Setting floats
Old Oct 6, 2005 | 05:16 PM
MatthewC's Avatar
MatthewC
Setting floats
Im trying to set the floats on my Holley 4180.
When I turn the screw to the left to turn the adjusting nut gas pours out of the screw. Is this normal? I turned the adjusting nut all the way to the right to lower the float level, and gas is just below the sight plug but the truck still wont idle well.
-Matt
Old Oct 8, 2005 | 02:12 PM
LxMan1's Avatar
LxMan1
Yes it is normal to get gas when you loosen the retaining screw.
Just below the site plug is where it should be. There are 4 hidden idle mixture screws on a 4280. The access plugs must be drilled out in the baseplate.
Old Oct 8, 2005 | 04:20 PM
MatthewC's Avatar
MatthewC
Thanks for the reply, but I just ordered an Edelbrock 600 cfm. That pretty much solves my float problems. LOL
-Matt
Old Oct 9, 2005 | 12:45 PM
LxMan1's Avatar
LxMan1
I've had good luck with the Edelbrocks myself.
