gear ratio?
Old Oct 6, 2005 | 04:07 PM
parkerusmc's Avatar
parkerusmc
gear ratio?
Need some more help guys. does anyone know what size gears they were putting in my truck? It's a 69 f100 2wd (360 with a c6.)
Old Oct 6, 2005 | 04:36 PM
BobbyFord's Avatar
BobbyFord
Look on the pinion side of the diff, attached to one of the nuts should be an ID tag.
Or, check your door tag for an axle code.
Old Oct 6, 2005 | 05:40 PM
4Cammer72's Avatar
4Cammer72
it should also be stamped on the passenger side axle tube facing the back of the truck close to the center chunk.
Old Oct 7, 2005 | 08:05 AM
jowilker's Avatar
jowilker
Parker, A lot of them came with 3.00 & 3.25 ratios, but anything could have been ordered in or swapped in since 69.
Roll the truck on very level ground one tire revolution and count the driveshaft revs. That is the best way to tell for sure what the actual ratio is.
John
Old Oct 7, 2005 | 01:09 PM
parkerusmc's Avatar
parkerusmc
Thanks for the help guys!
