First self done Oil change.
Old Oct 12, 2005 | 07:45 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Model number F-111
Old Oct 17, 2005 | 05:13 AM
ROKNZRX's Avatar
ROKNZRX
Got my Fumoto Valve in the mail the other day, now I cant wait to do my next oil change to install it. Although having the '04 F250 4x4 lifted 8" helps, all I do is slide a 5gl. bucket under oil drain plug, and let her flow till she is done. Now with the new valve I won't have to drag anytools under with me!
Old Oct 17, 2005 | 06:41 AM
BritishBartender's Avatar
BritishBartender
Originally Posted by BigF350
Model number F-111
Thanks, nipple or no nipple!! Does it matter??
Cheers,
BB
Old Oct 17, 2005 | 08:23 AM
Grizz49's Avatar
Grizz49
Just my two cents, if you are buying your filters from Wal-mart, they also sell the filter from Fram as well as Motorcraft. Open the boxes, the filters are exactly the same. However the Motorcraft on costs more.
Old Oct 17, 2005 | 09:51 AM
roozter's Avatar
roozter
Another thumbs up on the Fumoto valve. I had an issue with oil leaking at my drain plug. Ford dealer gave me about 8 of those carbon fiber? washers and suggested that I replace the washer at every oil change. Instead, I got the fumoto valve. No I have no leak and no worries about dropping the plug or getting burnt by hot oil!
I like it so much I am gonna get one for my Expedition as well.
Another tip. A 5 gallon bucket from Home Depot fits perfectly under my 4x4. Although it does have the 2" leveling kit and 35" tires. I can then put a lid on the bucket and drive it to Autozone or other place that accepts oil and dump it
I also fill only 13.5 quarts.
Concerning the fill hole, I have a yellow funnel that happens to be just the right size that I can thread it into the fill neck and pour in the oil. I also learned another tip from RV today. You can take one of the plastic quart bottles for margarita mix, tequila, etc., cut off the bottom and it will thread right into the filler neck.
-Scott
Old Oct 17, 2005 | 11:56 AM
big inch's Avatar
big inch
You can also cut off the bottom of a used 1-quart oil bottle. It will fit right in the oil filler neck.
Old Oct 17, 2005 | 01:15 PM
booker250's Avatar
booker250
I would have tried that, but I only had 1 gal oil bottles to work with. Too big.
I bought a good funnel the other day.
Old Oct 17, 2005 | 01:32 PM
ford390gashog's Avatar
ford390gashog
they are by no means filter so do not confuse the atomic orange piece of junk with the Purolator filter. yeah the mc costs more but you get more. the nominal micron rating is 17 on the mc and 24 on the fram.
Old Oct 17, 2005 | 05:21 PM
mrxlh's Avatar
mrxlh
Gashog, you had better go to china-mart and look for yourself. They are both the same racor quality, same numbers, same o-rings and instruction sheet. These are cartridge filters, not spin-on's.
Ryan
Old Oct 18, 2005 | 01:25 AM
rray32539's Avatar
rray32539
Ryan
The hog is right....stick with the Motorcraft or anything else but a Fram. Just take a hacksaw to one and look inside. It will make you a believer. I've seen the 6.0 oil filter at Wally World for about $13. Cheap.
Old Oct 18, 2005 | 05:34 PM
mrxlh's Avatar
mrxlh
You guys just don't get it do you. Fram is not making the filter, racor is. Fram is repackaging it, for now. So what part of $4.00 saved do you not understand, these filters for the time being are identicle, when and if fram does start producing, or should I say champion labs starts producing them for fram, then I will buy motorcraft. You don't have to cut it open, as it is a cartridge filter, NOT a spin on.
On edit, no, don't buy any of the $4.00 cheaper frams, that way their will be more left for me to buy.
Ryan
Old Oct 19, 2005 | 02:29 PM
BuCKxWiLD's Avatar
BuCKxWiLD
Where are you guys getting the oil filter o-ring?? or are you reusing the old one?
Old Oct 19, 2005 | 02:52 PM
  #28
sgthawkusmc's Avatar
sgthawkusmc
Comes with the filter.
Old Oct 19, 2005 | 02:54 PM
  #29
BuCKxWiLD's Avatar
BuCKxWiLD
ahh.. i see.. i just ordered the filters so hopefully they do come with it. thanks!
Old Oct 19, 2005 | 03:03 PM
  #30
roozter's Avatar
roozter
Or even better get them from one of the sponsors! I ordered in bulk for my 6.0 and my expedition. Oil Guard usually runs an $11 per filter deal.
