Offroad & 4x4
Will these tires fit?
Old Oct 6, 2005 | 01:34 PM
Stroker_Deezel's Avatar
Stroker_Deezel
I have a 77 Datsun truck, and i want to run 49" iroks, will they fit with my 6" body lift? Also, what kind of lockers are available? Do you think my stock 4cyl and 2.73 gears will be alright?
Old Oct 6, 2005 | 01:53 PM
Thomasm67's Avatar
Thomasm67
YOur probly gonna either add more lift or do alot of cutting and no your gears would need to be atleast 4.56 gears at the minimum. and plus your axles would never hold up to those 49's and you would probly need a better Tcase.
Old Oct 6, 2005 | 02:26 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
prolly need to gear higher to around 1.5:1....that way your axles shafts will hold up
Old Oct 6, 2005 | 02:46 PM
fishmanndotcom's Avatar
fishmanndotcom
only if you run slick 50!
-cutts-
Old Oct 6, 2005 | 02:47 PM
ATVer1992's Avatar
ATVer1992
4 banger? good luck!
Old Oct 6, 2005 | 02:48 PM
Stroker_Deezel
Yo Fishy, i heard slick 50 is da bomb, is that true. I heard lift blocks are the way to lift it too, is that right?
Old Oct 6, 2005 | 02:53 PM
BigBlockF-250II's Avatar
BigBlockF-250II
I'd reccomend lift blocks in the 10" flavor. They will be just the ticket for running 49's. Plus, I'm sure your Datsun leaf springs are so stiff that axle wrap will not be a problem whatsoever, even with 10" blocks
Edit: be sure to run blocks on the front too, that seems to be the 'cool' thing to do these days...
Old Oct 6, 2005 | 03:00 PM
Thomasm67's Avatar
Thomasm67
Thinks i fell for a joke sighs oh well.
Old Oct 6, 2005 | 03:01 PM
Stroker_Deezel
Yeah, you sure did...
Old Oct 6, 2005 | 03:20 PM
JeremyH's Avatar
JeremyH
Dont forget one of these bad puppies so that you can get 183 mpg:
Old Oct 6, 2005 | 03:47 PM
monsterbaby's Avatar
monsterbaby
remember that you are going to have to get the steering geometry corrected so to do that just cut the pitman arm in half, and weld a piece of rebar 10" long pointing down, then reweld the other half to that.
Old Oct 6, 2005 | 07:24 PM
fishmanndotcom
welding is overrated esp for steering parts. JB weld does good with a couple wraps of duct tape
-cutts-
Old Oct 6, 2005 | 08:00 PM
KubotaOrange76
just lower the whole sttering box down using jb weld and rebar
Old Oct 6, 2005 | 08:04 PM
ATVer1992's Avatar
ATVer1992
just fab up new tie rods out of rebar, run them straight from the original pitman arm. Bend them to pretzels to make em fit. Alignment? ha who needs that.
Old Oct 6, 2005 | 08:22 PM
mustange70's Avatar
mustange70
Don't forget about the 10" body lift using hockey pucks .
