Offroad & 4x4
Wheel's
Old Oct 6, 2005 | 11:24 AM
Chumbucket's Avatar
Chumbucket
Wheel's
Do they make 15inch 8 lug rim's for older ford pickup's 1987 250 4x4. What would be any disadvantage??? This truck only see's road use no off road. Only reason i ask is if i get better price on 15inch Thank's
Old Oct 6, 2005 | 12:50 PM
ivanribic's Avatar
ivanribic
I don't believe a 15" rim will clear the calipers on your truck. I have seen then in an 8 lug but just don't think they're gonna fit.
Old Oct 6, 2005 | 01:05 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Ivan's right. I had a set of 15x10 steel white-spoke wheels with the 8 on 6.5 pattern for my 74 F200 (yes, 200...5/8 ton) but it had 12" drums all the way around and they fit well. Here's the kicker:
Would not fit on the front of a 77-up Ford w/disk brakes, but would fit on the rear of any of them with drums.
WOULD fit the front of a 98 Dodge Cummins, but WOULD NOT fit over the rear drums.....
Kinda stupid, huh?
Cody
Old Oct 6, 2005 | 01:30 PM
Stroker_Deezel's Avatar
Stroker_Deezel
if you get them with 2 3/4 backspacing they fit... they just stick WAY out...
Old Oct 6, 2005 | 02:52 PM
fishmanndotcom's Avatar
fishmanndotcom
without grinding on your calipers they wont fit very easily. like stroker said you can get some really backspaced wheels that might work.
-cutts-
Old Oct 6, 2005 | 02:56 PM
Stroker_Deezel
I know the backspaced wheels work, i have seen it on 3 diff dana 60's, they just stick way out...
Old Oct 7, 2005 | 10:30 AM
GreenSubmarine's Avatar
GreenSubmarine
The 2-5/8 bs rims do work, and they're fine on 60s. The problem on the 44s is that they tend to wear wheel bearings out quickly. Double quick if your rig sees any mud or water. Grinding the calipers works, I've seen it many times. I worry about doing it, so have never tried it personally. Why not take the money for the 15" rims, sell the 15" tires, and put them toward 16" or 16.5 stuff?
Old Oct 7, 2005 | 03:27 PM
ivanribic's Avatar
ivanribic
I'm running 3" backspacing and let me tell you those suckers stick WAY out there. This causes legality issues pretty much anywhere you are if you drive on the street. On top of the strain on wheel bearings it's also more load on the kingpins or balljoints. When I changed from 4 5/8" backspacing to 3" it gave me a whole new set of problems to solve in terms of stress on the front end. For the few $$ in savings that a 15" rim will give you it's not worth all the other hassle.
heikks
Feb 4, 2013 07:01 PM
79broncoxlt
1978 - 1996 Big Bronco
Dec 15, 2010 10:00 AM
400Nut
Oct 22, 2006 08:34 AM
kaufma43
1983 - 2012 Ranger & B-Series
May 1, 2000 02:11 PM
