maintenance
Old Oct 5, 2005 | 10:39 PM
zontral's Avatar
zontral
maintenance
First of all I am glad I found this forum...
now to my question, I have a 2002 f350 7.3.. I have about 106 thousand KM's on it. I'm just wondering when I need to do things like transmission fluid and radiator fluid changes. things like that. I change oil and oil filter every 6000 km's ..
And what other things should I start thinking about now that im getting up in the KM's.
Old Oct 6, 2005 | 03:59 AM
slack's Avatar
slack
I change my trans fluid every 30,000 miles and if your coolant isn't life time (I'm not sure on a 2002) I change that every 30,000 miles or every other year along with the coolant additive which I believe is FD 16? If you haven't changed your fuel/water filter the average time for that is somewhere between 10,000 to 15,000 miles. Hope this helps.I'm not sure miles vs km's.
Old Oct 6, 2005 | 08:13 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to Ford Truck Enthusiasts zontral. I'm glad you found this forum too .
If your coolant is green you should change it annually, as well as charge it with a supplimental coolant addative (SCA). It used to be called FW-16 at Ford, but I think they changed the name to VC-8...but it's the same stuff. If your coolant is the gold stuff it does not require the SCA, and should be changed every 250,000Km.
At least once a year on the tranny fluid, and every 24,000Km on the fuel filter.
