advice on stroker kit
Old Oct 5, 2005 | 04:19 AM
serving_time's Avatar
serving_time
I was just looking at some different stroker kits for a 351W. they stary at 377cid and go up to 427cid. Is there any reliability issues with going that big? I heard that a 331 from a 302 works fine, but a 347 is not reliable. Has anyone heard of any problems with any of the 351W kits?
Old Oct 5, 2005 | 11:05 AM
73FOMO's Avatar
73FOMO
I have been doing a bunch of research lately and from what I can find the newer 347 kits are fine, but I'm not sure on the 351 kits. On some of the earlier 347 kits the piston pin had some interference with the oil ring, but most have solved that now.
Old Oct 6, 2005 | 09:48 PM
petes79f150's Avatar
petes79f150
Go to www.strokerengine.com. This guy really knows his stuff. He's a nice guy and will be glad to answer any questions (if you can catch him when he's not too busy). He's got some really good deals on kits and motors both.
Old Oct 6, 2005 | 10:13 PM
Blurry94's Avatar
Blurry94
Bearing and cylinder wear is a bit accelerated with a stroker, but all depends on your application...how do you plan on using this rig???
Old Oct 11, 2005 | 12:14 PM
73FOMO's Avatar
73FOMO
Ocassional driver...not daily.
Old Oct 13, 2005 | 10:47 AM
MustangGT221's Avatar
MustangGT221
details...we need details...
Weight of vehicle, auto/manual, gear ratio, intended purpose (towing/hauling/off-roading/drag race/etc etc)...
HP/TQ estimates, budget, what do you want the power curve to look like? What do you want the torque and horsepower relationship to be like? (more torque than horsepower, at what RPMs? What redline RPM do you wish to have? What RPMs will the engine mostly be used in?
The parts you select will determine what type of power you're engine will make. Either a low RPM torque monster, or the other end of the spectrum a high RPM high horsepower screamer...
The more you can tell us the better we can assist you. We don't bite, talk to us
Brandy4ever
13
Nov 27, 2016 07:12 PM
Javier89F150
Aug 9, 2015 07:16 PM
RIKIL
Mar 20, 2009 10:38 AM
Brian460
Jan 7, 2003 11:31 AM
lvmoose007
Sep 29, 2002 09:36 PM
