Just be careful putting too many springs in the back of your ride. Too many springs in the back could cause the stiffest ride you've ever seen and could even cause the frame to develop cracks around the spring hangers. I had this happen to a 1990 Blazer I had. Instead of a lift block or even the right springs to lift the rear, the P.O put a HUGE leaf spring on each corner from I think a 1-ton to lift up the rear. When I changed them out I noticed cracks around the upper shock mounts and near the hangers. It sure rode better after I swapped them out to.
