rear end
Old Jun 19, 2002 | 08:46 AM
BubbasRacing's Avatar
BubbasRacing
rear end
i was wondering if a 79 1/2 ton 2wd ford truck had a 9inch rear in it and did they have any thing other than a 9 inch rear end in them from the factory thank you
Old Jun 19, 2002 | 09:16 AM
ecarter50's Avatar
ecarter50
rear end
A few have dana 44 instead of the 9" I believe F100 only.
Old Jun 19, 2002 | 10:45 PM
Jermafenser's Avatar
Jermafenser
rear end
Sometimes they came with a Dana 61. If your gear ratio is a 3.07 or 3.31, it is a Dana 61.
Dana44 is a front axle only.
Old Jun 19, 2002 | 11:22 PM
thitdog's Avatar
thitdog
rear end
There were a few dana 44's in the rear end. It is NOT only a front axle.
Lee
Old Jun 19, 2002 | 11:37 PM
trinogt's Avatar
trinogt
rear end
Removeable carrier (bolts in the front) should be a 9 inch Ford. They are a semi-floating axle. Bearings are pressed onto the axle shafts.
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
Old Jun 20, 2002 | 08:53 AM
ecarter50's Avatar
ecarter50
rear end
I have a 77 and 78 F100 with dana 44 rear axles.
Old Jun 20, 2002 | 10:09 AM
laptopgeek's Avatar
laptopgeek
rear end
