Which Drive shaft?
Old Oct 4, 2005 | 03:27 PM
94bonestocker's Avatar
94bonestocker
Which Drive shaft?
Does anybody know if I can re-use the driveshaft from my 3 speed W/OD on my T-18 Swap?
Old Oct 4, 2005 | 05:08 PM
andym's Avatar
andym
Wouldn't it be easier to measure the two, given that you've provided no identication of the 3-speed you're swapping out?
There weren't too many three speed overdrives ever made. Are you sure it isn't a four speed? The number of speeds is the number of forward gears - including granny gear and overdrive.
Old Oct 5, 2005 | 04:18 PM
94bonestocker
It's the 4 speed, (3sp w/od) RTS or TOD whichever you wish to call it. I haven't picked up the T-18 yet, that comes in on friday. I will measure when i pick it up friday morning. I was just hoping someone had already done a swap like this and knew if it would work.
