'05 Integrated Brake Controller / Trailer Wiring Problem
Old Oct 3, 2005 | 11:05 PM
FormerRammer's Avatar
FormerRammer
I just wired a new 7 way plug receptacle into my bed for my fifth wheel. Is there supposed to be continuity between the +12v wire and the blue brake controller wire on the receptacle? I was very very careful in not cross wire anything, but I have made worse mistakes. Also, I keep blowing the 20 amp fuse on the +12v line under my dash (which may also argue for some sort of touching between wires).
Old Oct 17, 2005 | 11:30 PM
bckhntr's Avatar
bckhntr
At what point does the fuse blow? Right away or when you plug the trailer in?
Old Oct 18, 2005 | 12:07 AM
FormerRammer
I'm not sure. I will check it more closely when I get my trailer back from service (warranty work).
