need clutch help
Old Jun 19, 2002 | 09:23 AM
79workhorse's Avatar
79workhorse
need clutch help
I have a 1979 f150 2wd with a 300 6cyl and a clark 4 spd overdrive
The clutch is going fast and the olny place i have to work is out in the boonies so multiple parts runs are going to be difficult. I know the engine is not original to the truck but i don't know if its a 79 engine or not.
I see clutches listed for for 73-77 and 78-79. whats the differeces between them? and will it matter if the engine is a 77 or a 79?
i'd like to put a flywheel in it too.
any help would be great, I'm new to this ford stuff.
Old Jun 19, 2002 | 09:53 AM
dfisher1's Avatar
dfisher1
need clutch help
79,
Buy your parts for a 79 and be done with it.
KingFisher
Old Jun 19, 2002 | 10:43 AM
79workhorse
need clutch help
anybody know twhat the flywheel differences are between years?
balanced differently? or just a different part #?
Old Jun 19, 2002 | 10:18 PM
Mike W's Avatar
Mike W
need clutch help
There is a Ford SVO tech line you can call that would know the answer (I can't find the number). My guess is a different size or type of clutch. Diaphram type is better. Do you have any info on the transmission, sounds interesting.
Old Jun 20, 2002 | 04:26 PM
dan15000's Avatar
dan15000
need clutch help
Old Jun 22, 2002 | 09:32 PM
serian's Avatar
serian
need clutch help
>interesting.
The clark 4 spd overdrive was used in 80-86 models.
I have also seen it referenced as the "Ford TOD 4-speed".
This transmission seems to have gearing like the old
Ford 3.03 3 speed with an additional overdive gear, but
the transmission itself is much smaller and lighter
than the 3.03 or the NP435. It is a "top loader" style
and all the linkages and rails are internal. I have one
of these transmissions in my 86 F-150 4x2 behind a I6-300.
The overdrive gear isn't worth a glob of high-speed snot
in the mountains of Pennsylvania, but it makes for a
good highway cruising unit.
