Trans Temp?
Old Oct 3, 2005 | 06:33 PM
Rodzilla71's Avatar
Rodzilla71
Trans Temp?
I installed a set of Autometer Phantom gauges and went out for a drive with my Bully Dog Power Pup set on Extreme for about 20 minutes. Trans Temp never got over 160. Does this sound about right or is it a little low? I was bagging on it to see what the Pyro would go up to also, peeked at about 1200 in short bursts. Boost gauge is also a lot nicer to read then stocker. Chime in if you know what temp that trans should be running at and thanks in advance.
Old Oct 3, 2005 | 06:44 PM
barnbridge's Avatar
barnbridge
Smile
My engine is stock and the trans gets to 165 and stays there unless it's very hot outside or I'm towing a 6000* trailer. Sounds like yours is about right. I would think revving the engine would keep the tranny cooler than lugging the engine.
