Engine Surge In 93 Ford Explorer
Old Oct 3, 2005 | 12:35 AM
snipinu's Avatar
snipinu
Arrow Engine Surge In 93 Ford Explorer
While my 1993 Ford truck is in drive say at a stoplight and the heater blower motor is running the engine surges and the truck tries to move forward, I have had the alternator checked at Autozone and the voltage is 13 V to the Battery.
Any ideas?
Stumped.
Old Oct 3, 2005 | 06:19 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 3, 2005 | 04:00 PM
87 XLT's Avatar
87 XLT
Check the voltage yourself. With engine off check voltage, then start it & check again. should be around 14 volts.
If it doesnt change the alternator isnt charging.
Edit
Take a look at a wiring diagram, there might be a fuse for the alternator.
If there is check to see if it's good.
