2100 Fast Idle Setting
Old Oct 2, 2005 | 04:40 PM
scottlane's Avatar
scottlane
I rebuilt the Autolite 2100 that came on my recently acquired '76 F150 w/302. It came with the "real" manual choke (totally cable operated). My question is this: Is there any reason to worry with the fast idle adjustment? I can't see any reason for working on the stop point since the cable driven choke would override any setting made to the cam, and setting the stop screw too far would hinder the opening and closing of the choke plate. Am I right on this or am I missing something?
Old Oct 2, 2005 | 09:40 PM
LxMan1's Avatar
LxMan1
You have to push the throttle down when closing the choke so that the cam will pivot under the screw.
Old Oct 3, 2005 | 04:59 AM
scottlane's Avatar
scottlane
I'll have to look at it again. I swore that the cam was being overridden by the choke cable. If it isn't it makes much more sense. I have a Weber set up the same way on an old CJ and it works as you described. I guess I spent way too many hours this weekend bringing the beast back to life!
