Springs? Need help locating
Old Oct 2, 2005 | 02:38 PM
77300i6's Avatar
77300i6
Exclamation Springs? Need help locating
I am in dire need of a E-brake spring. You know, the one that mounts to the front E-brake cable and the rear cross member. Does any know where to get one? I have looked in every catalog I have and no luck (LMC, JBG, NPD, ect.)
I don't want one off a junk vehicle that's been sitting, that's how mine broke, lol.
Also, does anyone know where to get a clutch return spring, I can't seem to find those either.
Thanks as always for you help.
Old Oct 2, 2005 | 10:27 PM
deisele75's Avatar
deisele75
That seems like something you could get at a hardware store.
Old Oct 3, 2005 | 07:37 AM
User 71024's Avatar
User 71024
The auto parts stores usually have a decent selection too, but they can't look them up so you have to shop by sight.
Old Oct 3, 2005 | 07:38 AM
77300i6's Avatar
77300i6
Anyone know what amount of tension (in lbs.) the should have?
Thanks.
Old Oct 3, 2005 | 07:59 AM
User 71024's Avatar
User 71024
Thanks.
It's really a crapshoot, the clutch spring can be extremely strong, the ebrake just has to return the lever. the auto parts store should have a Card of clutch springs, if you have the old one to go by just pick a similar size and try it.
Old Oct 3, 2005 | 09:41 AM
thesprocket26's Avatar
thesprocket26
For the brake cable, get two from the parts yard. That way there is half the strain on each spring. As for the clutch return spring, find one that will do the job. I'm pretty sure there is a somewhat simple formula to calculating the strength of a spring. I remember that topic from high school physics. Find a spring that is as strong or better.
