Sponsored by: Real Truck
no heat
Old Oct 2, 2005 | 09:14 AM
sdpj's Avatar
sdpj
no heat
found out yesterday while coming home from boise im not getting any heat. was driving on the interstate for about 30 minutes so the motor was good n warm. fan was all the way to high and it was just cold air. any ideas?
Old Oct 2, 2005 | 10:51 AM
RR 11's Avatar
RR 11
My first check would be the hot water valve. It is by the heater box in the inlet line.
Old Oct 2, 2005 | 11:03 AM
Bigfront's Avatar
Bigfront
This may be a stab in the dark...but here goes. My 2000 SD would only allow the heated, cooled or vent air to come through the defroster ducts. It was still under warranty (otherwise a $300 job) and the dealer replaced the blender motor (I think thats what they called it?). I guess this motor controls the route that the air is able to flow through, depending on the position of your controls. I'm not sure if a similar device allows the heated air to enter the truck. Perhaps another FTE user can move forward on this?? GOOD LUCK!
Bigfront
