General Automotive Discussion
oil change
Old Oct 2, 2005 | 03:33 AM
ford390gashog's Avatar
ford390gashog
oil change
here is the step by step oil change listed on fords website. hummm what is missing here.
How To Change Your Vehicle's Oil
Park on level surface.
Turn off engine and allow a few minutes for oil to settle.
Put vehicle in PARK.
Set parking brake.
Open hood and locate oil dipstick (usually has small hook-like handle). With a rag, wipe measurement section (lower tip) clean.
Insert it back fully into the engine. Make sure it's all the way in to get an accurate reading. Remove and observe tip.
Level should fall between MIN and MAX. If oil line is below MIN, oil needs to be added.
Replace dipstick into engine.
If more is needed, locate oil cap. It should be marked—check Owner's Manual if you can't find it.
Add the recommended weight oil into engine. (Use a funnel if necessary). If any spills onto engine, wipe it off.
Be sure not to overfill (beyond MAX line), as this could cause engine damage. If in doubt, add a bit and then check level. Repeat until correct level is achieved.
Replace Cap.
Old Oct 2, 2005 | 03:52 AM
pursang's Avatar
pursang
I'm assuming they should've replaced "Change" with "Check" what surprises me is when they tell you to shut the engine off before putting it in park.
Old Oct 2, 2005 | 05:31 AM
texans's Avatar
texans
it never said to drain the oil. man that is funny. what is up with that part about turn off the engine then put it in park? Someone should write to ford and have them correct this. Good find
scotty
Old Oct 2, 2005 | 09:24 AM
Icefan71's Avatar
Icefan71
That IS how some people change their oil!
Old Oct 2, 2005 | 09:41 AM
Tom's Avatar
Tom
Well, with a serious enough leak, you would EVENTUALLY change out all your oil this way!
Old Oct 2, 2005 | 09:53 AM
bigdaddyII's Avatar
bigdaddyII
My sister in laws husband changes the oil by unscrewing the filter and putting a new one on and than adding 5 quarts of oil, than when he blew the motor in his new grand am he was pissed cause it wasnt covered under warrenty. Some people. Ford needs to fix that or someone just like him will ruin their ride or hurt themselves trying to shut the truck off before putting it in park. At least it tells them to park on a flat surface.
Old Oct 2, 2005 | 11:45 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
I knew a guy that NEVER changed his oil in his F-150.
He swapped the oil filter, added enough new oil to top it off, and away he went!
The last time I saw him, was in 1993. He had over 275,000 miles on that old truck.
(I think it was a '82 F-150.)
Old Oct 2, 2005 | 04:39 PM
ford390gashog
there is a ton of this misinformation on the ford site. just type in ask kate in the search. they even give a lesson on spark plugs and fluids.
