Frame swapping questions
Old Oct 1, 2005 | 11:23 PM
1969Stang's Avatar
1969Stang
i have a 77 f250 460 c-6 2wd extend cab long bed. and i found another extend cab long bed 4x4 that needs a lot of work. I have searched the forums and it appears that swaping the frame would be the easiest thing to do. its a 79 will that cause a problem. its a stick and i don't know the size motor. what would i have to do to mate it with the transfer case. would i have to change the drive shaft lenghts cause it would be a man. to auto conversion basicly. how long do you think this conversion would take. and how much money would it take.. i'm tired don't really want to do any more searching. so thanks for your help i get to go get 4 hours of sleep before i go to work......yea.
Old Oct 1, 2005 | 11:25 PM
1969Stang's Avatar
1969Stang
oh and if i leave it how much is it worth.. there is only a little rust in the driver rear corner and both side drip rails. and the interior and truck other wise are in great condition. thanks.
Old Oct 2, 2005 | 10:04 AM
Mil1ion's Avatar
Mil1ion
Hi & Welcome to FTE,
May I suggest titling the thread with the actual topic ?
It makes it a lot easier for everyone (other new users) when searching the subject.
You may want to read the FAQ thread attached to the top of this forum for other tips.
Old Oct 2, 2005 | 10:21 AM
STGFordCrazy04's Avatar
STGFordCrazy04
Stang,
A few questions:
Are you swapping the 460 out of the 2wd truck?
Do you care about the body on the donor frame?
Does the motor and trans appear to be in good shape in the donor frame?
Are you trying to restore or just take 2 trucks and make one?
If you are trying to piece 2 together here goes.
If you have both truck sitting side by side I would enlist the help of about 4 buddies, the cab and bed are rather heavy. first unbolt the front clip all in one piece ( the 3 bolts on the firewall that hold the inner fenders on. the one bolt on the bottom of the fender that bolts to the cab. and the radiator support bolt might have to be cut. repeat for the passenger side.) Then unbolt the bed. Now thats out the way unbolt the 4 bolts ( I think. never delt with an extended cab. maybe 6) that hold the cab on. Then you will need to disconnect a few wires ie ground wire on body mount, parking brake cables, and trans linkage. then just lift it off. and set it to the side. Then if it were me and I didnt care about the other truck body Id break out the ol torch and repeat. When you have the bare frames sitting there you could easily swap motors and trans. Then put it all back together. I would say cost of renting your buddies I would suggest new bed bolts cab bolts and rad support bolts at minimum grade 8 only. So, about $30 in bolts + time. If you had all day Sat and Sunday youre mildly mechanically inclined and you werent swapping the motor I think it could be done. Good luck hope it helps
PS tell me about your 69 Mustang. I have a 69 Boss 302.
Old Oct 2, 2005 | 02:05 PM
Hypoid's Avatar
Hypoid
A 4 hour nap before work; I resemble that remark.
More information about the 4 wheel drive truck would be helpful:
Which model is it?
Is the transfer case divorced, or is it mated to the tranny?
I recomend posting in the offroad and 4x4 forum. Some of the guys there have done a lot of fab work on F-250s. They know these drivelines and chassis inside out.
Good luck, Mike
Old Oct 4, 2005 | 08:49 PM
1969Stang's Avatar
1969Stang
would be using just the frame and the drive train other then my motor and trans. and for my 69 its a coupe with a 331 in it. and its going to have a nice t88 turbo to go with it in a bit. going to be getting a set of heads and god knows what else. lol. already did a front disk conversion going to be going with the rear also. its medowlark yellow for now and in the process of doing the interior. so now that i think about it. i don't think i'm going to do the swap.. too much work money so on and so on. and thanks everyone for the advice and for replying. oh a the boss always rule.
