Modular V10 (6.8l)
2007 Vvt V10?
Old Oct 1, 2005 | 08:54 PM
nisiar's Avatar
nisiar
2007 Vvt V10?
Reading Autoweek this week, and they describe the new GM SUV/truck line as having new engines . Topping the line are gas 6.2l w/vvt in 390 and 400hp versions. Below that falls a 6.0l with vvt and displacement on demand with 355hp.
Will Ford let this challenge fall unanswered? Remember, the head castings for the 3v v10 have the neccesary fitments for the VVT. I thinks we now know why! (my guess is 400hp and 490 ftlbs)
Old Oct 1, 2005 | 09:39 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
YEAH!
Yee HAH!
Too bad I'm hanging on to my '01 for a long while
Old Oct 2, 2005 | 10:01 AM
RUBICON's Avatar
RUBICON
vvt v10
ford had better wake up because the other manufacturers are eating us alive
Old Oct 2, 2005 | 12:05 PM
cc322's Avatar
cc322
In what area are they eating us alive?
Old Oct 2, 2005 | 01:00 PM
captchas's Avatar
captchas
Guest
yah wake up ford vvt would help unreal, esp with the new intake. or maybe that super charger kit from ford racing
Old Oct 2, 2005 | 01:40 PM
Wrenchtraveller's Avatar
Wrenchtraveller
I hope the 07 model has the V10 pumped up big time.
If that is true about Chev offering a 400 HP gasser, Ford has to beat that for sure.
I wonder if Chev is going to try and match Ford's payload in SRW pickups.
Old Oct 2, 2005 | 04:30 PM
captchas's Avatar
captchas
Guest
chevy doing 400hp. lets remember they still use push rods and a small block design. and 2 valves. the v10 is a ohc, 3valve, ford should be able to twist this motor out a lot more then 400hp with no sweat
Old Oct 2, 2005 | 06:51 PM
cc322's Avatar
cc322
And they will, no way will Ford let GM beat them at the truck game. Now the suv market well maybe
Chevy ...Chevy... made of tin, drive em out push em in
Old Oct 3, 2005 | 12:18 AM
NickFordMan's Avatar
NickFordMan
Charlie, glad to see you decided to stay around a while longer. The V10 should easily be able to handle WAY more then 400 hp, but to be conservative, Ford won't let GM beat them.
Old Oct 3, 2005 | 08:05 AM
krewat's Avatar
krewat
Sure, they can get 400 HP just by moving the RPM range up, but what would that do for low-end torque?
I admit, with VVT, they should be able to get low-grunt and high-end too...
Just lengthening the torque curve without any increases would up the HP quite a bit - but then, we're back to marketing BS in regards to HP.
Speak in terms of TORQUE - not HP - that's one bee in my bonnet
Old Oct 3, 2005 | 03:42 PM
V10KLZZ71S's Avatar
V10KLZZ71S
I believe that since Ford Racing just started offering headers for the 6.8 you can bet the engine isnt going away.We get beat a bunch in the hp wars, but make superior trq.I would believe they are already Testing some VVT engines.Maybe we could get a slight cu. in. increase.
Old Oct 3, 2005 | 04:30 PM
NickFordMan
Well, the 5.4L has excellent low end torque, and winds out really well. Torque is the only thing that really matters when talking about gaining more hp, but with the VVT, the torque curve should be pretty flat, and thats with a massive amount of low end.
Old Oct 3, 2005 | 04:40 PM
captchas's Avatar
captchas
Guest
ford racing has more then just headers for this motor, you can add a whipple charger kit and and plated valve covers for the 3 valve. my thinking is they have some thing up the old sleve.
v10 klzz71 you can thank tim, and a lot of others about my posting.
Old Oct 3, 2005 | 07:03 PM
cc322's Avatar
cc322
Does anybody have a web site for the Ford racing headers?
Old Oct 3, 2005 | 07:06 PM
captchas's Avatar
captchas
Guest
http://www.fordracingparts.com/home/home.asp down load the high speed haulers catalog every thing truck is in it
