two questions
Old Jun 25, 2002 | 11:33 PM
villagidit's Avatar
villagidit
two questions
two questions i have 1973 f-250 stock what transfer case do i have and how do i get it to quite moving so bad when i use the gas ?
second or i guess third my transfer case only shows 2wd and 4wd does it not have the 2h and 4l all 4x4 i have owned have was just curious. thanks
Old Jun 26, 2002 | 04:40 AM
karljay's Avatar
karljay
two questions
>i have
The stock 73 F250 4x4 should be a divorced NP205 2speed TC.
>the gas ?
I don't understand the question here, but you should be starting in 2nd gear (assuming 4 speed) with TC 2HI for street driving. Whats the actual problem your having?
I've heard about other TC's in these years, but never thought they were stock. My NP205 had a tag screwed onto the front part. It's about 2" x 3" and light blue with 4 screws in it. I'd look for a tag on yours. Maybe someone swaped something around.
Old Jun 26, 2002 | 06:41 AM
tellico racing's Avatar
tellico racing
two questions
I have a 69 1/2 ton with the single speed t-case. I dont remember the model # of the case, but it still works good after 33 years.
Old Jun 26, 2002 | 03:36 PM
villagidit's Avatar
villagidit
two questions
i do start in second due to granny low what im saying is my whole t case is moving under the torque like relly bad i do have a small plate pinned to my t case what exactly does this mean thanks again
Old Jun 26, 2002 | 04:41 PM
leadmic's Avatar
leadmic
two questions
One of two things eather the transfercase is loose from the adapter in which case you need to find out why. Or the second and more likly is your motor mounts are bad. Try opening the hood set your parking brake and giving it a little gas with it in gear watch the air cleaner on the eng. if the engine moves and looks like its trying to climb out you have bad motor mounts if just the transfercase shifter moves it or somthing hooked to it is loose. Hope this helps.
Leadmic
Old Jun 26, 2002 | 05:22 PM
jaysonb's Avatar
jaysonb
two questions
The single speed T-case should be Dana-21. They are pretty good, but will break if spin the wheels too much in sand or mud, it will break even faster if it transferring the torque from a fresh 'built' 390...
Are you sure the whole thing is moving, or is it just the shifter, the only reason I ask is that my shifter would move around and rattle when under load. It turned out to be caused by some slack in the linkages. Hope this helps.
Jayson
Old Jun 26, 2002 | 05:30 PM
BB's Avatar
BB
two questions
Hey villagidit, I just "got" your username, very funny!
Barry
Old Jun 27, 2002 | 06:59 PM
villagidit's Avatar
villagidit
two questions
the stick moves a little but if i let off the gas and hold the shifter then give it gas it kicks my hand back real hard cause it moves the stick so hard this is all under moving conditions so if my transfer case only has 2wheel and 4wheel on it that means i have a what? thanks for helping
Old Jun 28, 2002 | 09:56 AM
WC76TX's Avatar
WC76TX
two questions
Village...
the transfer case you have is a dana 21.
they came in ford half tons between 69-76.
sounds like you need to replace your tranny and transfer case mounts, possibly your engine mounts too. it should not move that much.
Will
Old Jun 28, 2002 | 10:03 AM
jaysonb's Avatar
jaysonb
two questions
>conditions
Have you tried this while driving in 4-wheel drive? See if the symptoms are the same or if they differ from 2 to 4 wheel drive.
This means you have 2-high and 4-high, you don't have a low range. As I said before it is most likely dana-21 T-case. Although I thought that they only put them in half-tons. It is possible that someone swapped this in your truck. If so, the maybe the shifter symptoms are an alignment issue. Just speculation here, trying to think of things for you to check out...
Jayson
Old Jun 28, 2002 | 12:12 PM
JTY's Avatar
JTY
two questions
PSDlongbox
Jan 20, 2013 07:11 AM
73BlackBeauty
Jan 12, 2009 04:57 PM
wge
Aerostar
Dec 9, 2003 03:08 PM
el conquistador
1983 - 2012 Ranger & B-Series
Dec 6, 2003 07:08 AM
mudrider
Jun 27, 2002 06:31 AM
