Well, it seems I only come on here with problems. Last one was a dead alternator and now it seems much worse.
I was driving back from advanced auto picking up my new alternator, and as I was driving back I suddenly heard a loud knock/engine noise.It was RPM dependant. It resembled the sound of an open header/exhaust manifold. Thats the best I could describe it. It was definately coming from the right bank of cylinders. The motor still ran, but seemed to be a little down on power, but I turned it off as soon as I could and pulled off the road.
I had a very very light knock before this, and didnt pay to much to it, which know I am regretting.
yea, I was a little vague. I am pretty sure it wasnt exhause noise, but I turned it off pretty much right when I heard it.I checked for an exhaust leak, but I didnt see anything(but was on the side of the highway so I didnt look all that closel)
I restarted it for about 30 sec. while I was parked and tried to figure out what it could be. It was definately on the right bank of cylinders, occured during coasting/throttle/and idling. As long as the motor was on/the noise was present. It was dependant on RPM. There also seemed to be some sort of fluid/looked like oil right near where the noise was present(near spark plugs/intake manifold/valvecover) Not sure if it was there before or not.
I will also mention that if I let the truck sit for an extended period,like a week, I would hear a loud surge/dull "pop" right when I started. It would return to normal warmup idle in about half a second.
I will say the truck is still relatively new to me, and my engine knowledge is lacking.
I will guess that the sound was coming towards the rear of the engine/ maybe cylinders 8,9,10
Did you by chance smell gas ? when running ?
Look for a blown sparkplug then. passenger side last one back!
Did you pull the dip stick chk oil for water/antifreeze smell
Either way sounds like bad news .
Good luck
Rich
It sounded like exhaust, as I have broken the flange that attaches the manifold to the exhaust before on my offroad rig, and it sounded similar. But I didnt visually check all that great(was in nice clothes on the side of the highway) I will pray that is the problem, since someone said it was somewhat common.
Could be a blown sparkplug as well. It is at the dealer now and well see what they say. I would like to tackle the repair myself, but who knows
Well, Ford says the #1 sparkplug blew. They est. total cost to repair would be around 3300 for parts/labor!! I am not going to pay that much on a truck that I got for 12K unless it gets me a new motor.
Have any of you done this before? They said you have to get to it from the #2 cylinder ect... Seems kind of a pain. I may start doing my research and seeing if I can save myself some $$$.
I've had the truck for about 4 months... I am kind of dissapointed, but I guess thats what you get for buying a used truck with high miles. I had the impression though the V10 was a pretty reliable motor. I guess I am unlucky.
I will check out your link... I would like to give it a shot, especially being a college student on a limited budget. I could keep it fueled, but 3300 is out of question.
Heres the parts list they quoted me:
1 left hand cylinder head:1500$
5 gaskets
1 head bolt
1 ignition coil
and some other misc. things like oil, antifreeze ect...
and 16 hrs of labor.
Check your spark plugs.
EDIT: just checked out your link, sounds interesting...may have to give that a shot, sounds reasonably simple compared to the alternative. Any comments about the procedure?
5 gaskets
1 head bolt
1 ignition coil
Just follow the instructions and save yourself a bundle. If you do, that particular plug won't blow again. Read up on it here by doing a search if you want. There's folks that have done it and have many miles on the engine.
Interesting info Big Orn . I use Heli coils all the time at work but this site claims that timeserts are even better.
Most of the chip refiners I change plates on come with heli coils for the fasteners.
Refiner plates are under heat and pressure and coupled to 15000 HP electric motors
and heli coils stay put under these conditions.
When we change the plates by removing the three 5/8 " diameter SS capscrew we scrape down the backing plate and if the heli coils have backed out of the hole enough to feel them with a scraper, we remove them and put in new heli coils.
Toa Disco , good luck getting a reasonably priced fix for this.
The timeserts seem like a decent alternative to head replacement. I hope the head is still salvagable to use the timeserts. I searched the site and this is a pretty common problem it seems. I wish I had caught this... as I did here the ticking, but delayed it until I was back home with tools/garage ect... I am kicking my self now. I am hoping I can do the repair without taking the heads off... I think I read that it was possible, just have to clean up all the metal shavings ect...
Thanks for all the advice, keep it coming. I could use the encouragement.
Thomas
I'm making an assumption here, Thomas, but I think there are a few trucks out there that have spit a plug, got the timesert thing done and was sold direrctly afterwards with no more than a few thousand miles on them. The problem was not disclosed, the new owner did not inspect for such a thing and has driven the truck many, many more thousands of miles. The helicoil is a great fix for this and, if you take your time, will last for the life of the engine.
