Tranny swapping
Old Sep 30, 2005 | 11:42 PM
t_lattimore's Avatar
t_lattimore
Smile Tranny swapping
Hey guys how's it going my name is Tom
My buddy has a 1991 F150 4x4 that we installed a 347 stroker engine in now we are having tranny problems it has a 4 speed auto tranny in it, we were thinking about installing a manual tranny out of a 1989 f150 2wd truck but we don't
know if the tranny will hook up to the tranfer case and was just kind of wandering if anyone has attemped this and if so will it work and what all do i need to transfer or buy new of
thanks alot for the help
Tom
Old Oct 1, 2005 | 12:01 AM
97Centurion's Avatar
97Centurion
Rub my Belly
Hey Tom! Welcome to FTE.
That's a tuff one. You might try asking in the tranny forum. https://www.ford-trucks.com/forums/f...splay.php?f=69
Good luck! Wish I could be of more help.
Old Oct 1, 2005 | 12:10 AM
t_lattimore
thanks man I'll give it a try if you happen to hear give me a shout
thanks
Old Oct 1, 2005 | 12:29 AM
fordborn's Avatar
fordborn
Tom, welcome to FTE and the Kansas Chapter, there are a lot of members that may be able to help on that question but as Centurion said above you might have better luck in the transmission technical forum. I am sure either way someone will be along to help shortly.
Old Oct 1, 2005 | 10:18 AM
ranger93's Avatar
ranger93
What you need to do is find out what type of manual trans was installed in the 4x4 from the factory. The 2wd tranny probably will not work due to length issues.
I am in the middle of trying to figure out how to stuff a 5.0 in a Ranger and from the info I have on that deal, it says you can use a T5 manual trans to hook up to the original transfer case with an adapter. You may not need any adapter for your F150, just do some researching and find out what the factory setup was...then go parts shopping.
Old Oct 1, 2005 | 02:30 PM
fordnut1985's Avatar
fordnut1985
Are the trannies the same model?? They should either be an E4OD or an AODE maybe even an AOD. Say it's an AOD, all you need is a tailshaft and output shaft from a 4x4 model and your t-case will bolt right up. If I remember in the 89's it would be an AODE but I'm not sure. Either way the computer won't be a problem, the old EEC-IV system dosen't know the difference between trannies.
Old Oct 1, 2005 | 09:42 PM
UnderTakr's Avatar
UnderTakr
If your lookin for a 4 speed Manual tranny for a f150 im the man to see. I will do ya a favor and swap ya the auto for the 4 speed!! It came out of a 86 F-150 with a 208 transfercase. I dont want a Manual but am lookin for a Automatic. If ya wanna trade just Private Message me and well set things up!! By the way it was hooked up to a 302. I have the flex plate also but the clutch is gone!! Just let me know!!
