F250 dual battery info here:
#46
#47
?When do I turn on or off the auxiliary battery?
(I definitely do wait for the glow sticks/plugs to go out before cranking the truck--but don't know how to utilize the dual battery and their switches)--thanks again for any help
#48
#49
The row of switches relative to the aux. battery??
The batteries are wired together, not separate, so if you're using the power port in the dash, it's utilizing both at the same time, with the potential of running both down. It takes both batteries to start your truck, so they are not isolated from one another and can't be.
Thanks so much for taking time to clarify this for me, I truly appreciate it.
#51
very useful....I understand its an old thread so no need to point that out. Just bought a 2005 f-250 crew cab lariat and need a location to install an isolated battery. plan on using an isolator that will allow aux battery to run down when motor is off while not draining the main battery. Under chasis is a perfect location. thanks
#55
Thanks for a brilliant idea. I got the box yesterday. After doing an explore under the chassis starting to get discouraged about placing it there. I must of mis-read and thought the bracket was already under there for a bolt on solution. not much room to do a ground level welding job down there and using bolt on clamps and brackets would only get me support using the top hole...it would probally slide on bumps. I saw the cables and thought the box tilted open for servicing but it dosent. I'm either going to put the box in my bed mounted tool box or scrap the idea and just use the box on my 18X8.5 trailer. It would fit pretty easy between the beams on the forward tongue. If I can find a stock intake filter maybe I'll scap my k&N cold air setup and put the battery box in the fwd right engine compart corner. But anyway...at least now I have a very good battery box.
#56
still inspired by the Op, was in a local hardware store today and found some metal sotck of the needed lenth with 4 holes of the optimal size in the right position. so 4 brackets, to bolted together for each side of the batter box and two bolts mounted with studs out ward, and the whole thing bolted right up. no drilling, cutting, welding, etc. no isolator for now. wired the pos to the started solenoid hot bolt. wired ground to a new bolt thru the frame. disconnected the original battery and the aux position battery started the truck right up....so everything is connected nice and tight. Sure beats having the battery in the bed mounted tool box. Thanks again Op for the idea to use an e-250 batter box. found a new one with the cover and wedge for 40 bucks.
#58
You should check out HiddenPower the under bed battery mount. It specially designed to be a no drill installation that attaches to the truck frame allowing you have extra power ready when you need it.
For more info and vehicle fits - HiddenPower - Under Vehicle Battery Mount
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
James_Western_Canada
26
08-09-2022 07:32 PM
BadDogKuzz
11-17-2014 01:28 PM
Thumper19
19
09-22-2014 04:47 AM
