Sponsored by: Auxito
Starter wont come off
Old Sep 30, 2005 | 09:51 AM
2ez's Avatar
2ez
Hey guys,
I'm trying to remove the starter in my 1997 F 150, need to replace the solenoid. I've removed the two bolts described in my Chilton manual, but the thing still won't budge.
Any suggestions would be greatly appreciated.
Old Sep 30, 2005 | 09:56 AM
spacedout's Avatar
spacedout
hold a block of wood on it and hit it with a hammer make sure you dont dent the case though
Old Sep 30, 2005 | 10:35 AM
l-m tech's Avatar
l-m tech
if you are trying to remove the starter there are 3 bolts that hold the starter to the trans bell housing.then 2 torques bolts hold the solinoid on.
Old Sep 30, 2005 | 10:44 AM
2ez's Avatar
2ez
Where is the third bolt? i found one on the bottom of the starter, and another up on the top corner. Is the third visible from underneath the truck?
Thanks again for your help.
Old Sep 30, 2005 | 03:53 PM
l-m tech's Avatar
l-m tech
if its a 4.6 or 5.4 there should be one on the bottom ,one on the outside side and one on top of the starter. 10 mm heads
Old Oct 2, 2005 | 08:46 AM
cleevesj's Avatar
cleevesj
The last bolt that you are probably looking for is on the top side of the starter and if you do not have a body lift in, it is very hard to get at. If I remember correctly, I used a 2 foot extension and it was still a pain in the butt.
Old Oct 2, 2005 | 08:50 AM
cleevesj's Avatar
cleevesj
When I put my starter back in, I cheated and only used two of the bolts. I have not had any problems yet. I also bought my starter on ebay and saved a ton of money. I got it for 63.00 including shipping. It was a new remanufactured. It has been in about a year and a half.
