Horn won't STOP!
For awhile there has been a clicking when I turn and sometimes it would get 'stuck'. Recently when I 'un-stuck' it some plastic started falling from behind the steering wheel. Now whenever I turn the horn goes off and sometimes when I am not turning. I was on way to work yesterday when I couldn't get it to stop. Pulled over truck and got emergency tools out. I removed steering wheel cover (92 w/o air bag) and started to probe. What I found was that the cruise and horn wires were all disconnected from the housing it plugs into. Not only that but the housing does not appear to be attached to anything anymore. When I fiddle with the copper coil thing (is this clock spring?) I can get it to stop, or at least subside.
Obvious solution is ditch cruise control and horn. But I need to pass inspections in less than 2 weeks, and I need a horn in DC. How screwed am I? Thanks in advance...
I left the top off of my bronco and the windows down for too long and
watter got into my steering wheel and my horn wouldnt stop either so...
I just riped out all of the wires (cruise control) and all of the springs and stuff.
and took the mold of the steering wheel and just filled it with bondo and painted it.
drilled a hole in the middle (for the wires) and put a push button horn switch right over the top of the hole. works fine for me.... and gives it that costomized look....
you can even put more switches over the bondo and hook them to your cruize controll wires in your steering wheel and cut the other side (under your bottom dash)
and hook them up as accessories, lights ect.....
thats just me....... good luck...
you can probably find a replacement on ebay or junk yard....
