speedometer
Old Jun 30, 2002 | 10:27 AM
F250mudder's Avatar
F250mudder
speedometer
My speedometer wasn't working in my '75 f-250. I went to a junkyard and got a new instrument cluster and installed it. It still didn't work. I think it might be the cable that runs from my transfer case to the speedometer. Could this be the problem and is it hard to fix. The cable that is on it now fell onto my exhaust and burned up a little but did not go all the way through to the cable. Any info would be helpful. Thanks
Tucker '75 3/4 ton "hi-boy" Dana60/HD44 360/2bbl.
Old Jun 30, 2002 | 01:56 PM
blueoval79's Avatar
blueoval79
speedometer
It is your speedometer cable. any burns or kninks in it will make it not function right. The speedometer cable is not hard to change. There is 1 bolt that is located on the transfer case and 1 bolt located behind the speedometer gauge.
Old Jun 30, 2002 | 06:47 PM
F250mudder's Avatar
F250mudder
speedometer
Thanks for the info. Should I get a one from a junkyard or should I buy a new one? Also where would i get a new one?
Tucker
Old Jun 30, 2002 | 08:38 PM
blueoval79's Avatar
blueoval79
speedometer
They are usually reasonably cheap in the $35-45 range. I'd go to NAPA if I were you. Better to play it safe and get a new one than get one 25 plus years old
Old Jun 30, 2002 | 09:09 PM
Franklin2's Avatar
Franklin2
speedometer
There is also a plastic gear that can get stripped in the transfer case. You should be able to pull the assembly out of the transfer case that the speedo cable screws to and check the plastic gear.
Old Jul 1, 2002 | 07:58 AM
F250mudder's Avatar
F250mudder
Post speedometer
Thanks for your input I will go to napa today. Does anyone know how to take off a steering wheel without a puller?
Old Jul 1, 2002 | 09:37 AM
79f3504x4's Avatar
79f3504x4
speedometer
Old Jul 1, 2002 | 10:06 AM
76supercab's Avatar
76supercab
speedometer
Nope but I got a cheap steering wheel puller out of the discount bin at my auto parts store for like $12. Just get a puller.
Old Jul 1, 2002 | 04:21 PM
F250mudder's Avatar
F250mudder
speedometer
I went to the website from where i got my steering wheel and they said you can just get one person on each side to pull like hell and it will seem impossible but it will eventually just pop off. Well i went to my truck and just pulled on the drivers side with a couple of tough tugs and it suddenly came right off. Didn't mess up anything on the column.
