Driveshaft
Old Sep 29, 2005 | 06:23 PM
importkiller62's Avatar
importkiller62
Question Driveshaft
I was wondering if any would know if I would need a longer driveshaft if i get a 4in suspension lift on my truck. Thanks
I have a 90 F-150 short bed and standard cab.
Old Sep 29, 2005 | 06:33 PM
Iron Horseman's Avatar
Iron Horseman
As far as I know, it should be ok. But if you do need one, it may be just as good to get a longer one and take it to a machine shop and have it cut and balanced.
Old Oct 1, 2005 | 08:55 PM
hybred's Avatar
hybred
you could also shim the spring pads a few degrees to lift your pinion angle some. most all 4wd places sell degree shims.
Old Oct 1, 2005 | 08:57 PM
chrono4's Avatar
chrono4
you should be fine with a 4 inch. are you gonna do a kit, or are you gonna do a shackle flip?
Old Oct 2, 2005 | 10:00 AM
importkiller62
I was gonna get the whole kit and new leaf springs for the rear not those retarted blocks
Old Oct 2, 2005 | 12:17 PM
chrono4's Avatar
chrono4
good choice,stay away from the blocks. you should be fine.
Old Oct 2, 2005 | 12:54 PM
MustangGT221's Avatar
MustangGT221
I have a 6" lift and don't require a longer driveshaft. When you've got a reg cab/short bed, than you're wheelbase is shorter and on a 6" lift you'd need a longer driveshaft, but on a 4" lift you're ok.
Old Oct 2, 2005 | 07:26 PM
importkiller62
Thanks for all the help guys its good to know that i dont have to worry about it once i receive the lift. Now i just have to worry about affording bigger rims and tires.
