Wrong Tranny Fliud added?
Old Sep 29, 2005 | 02:13 PM
crashed13's Avatar
crashed13
Tranny Fluid not Power Steering Fluid?
I notice my 94 F-150 Pick UP was a Little low on the power steering reservoir. So I stop at a Gas station and bought a bottle of "Power steering fluid" and put some in , WRONG!!!!
Now it makes a squealing sound and I find out that you only use Type F "Transmission Fluid" NOT "Power steering Fluid"when topping off the power steering bottle.
Now I'm told I have to get the power steering system flushed out to remove the power steering fluid I stupidly added back out or it will fry the power steering Pump! if it has not already.
I know you should read your manual first but I took a chance that I was right to add power steering fluid, like the time when I added gas to the gas tank also without consulting the manual.
Ford should have a warrning sticker stating
"WARNING do not put power steering fluid in your power steering"
I haved parked the truck and will get it flushed ,but is adding power steering fluid really as bad as I was told?
Old Sep 29, 2005 | 03:51 PM
tjc transport's Avatar
tjc transport
i ain't rite
never heard that one before. also, ford stoped specifing the use of type "F" trans fluid sometime in the early 70's.
Old Sep 29, 2005 | 04:17 PM
crashed13's Avatar
crashed13
My manual says use OEM Specifiction ESW-M2C33-F I think thats Type F Tranny Fluid.
Old Sep 29, 2005 | 04:52 PM
460smog's Avatar
460smog
I think somebody fed you a line. There might be a difference in the fluids, but either should work fine on it's own. To flush, (kinda messy) take the return side hose off and let er spill while the engine's running, and keep adding the fluid of your choice until it runs a consistant color. As a side note, ford power steering pumps have always been junk, and even new ones "moan".
Old Oct 23, 2005 | 05:06 PM
gdawghereiam's Avatar
gdawghereiam
fta is supposed 2 b the best but when u need juice in there real fast,i dont think that p/s/f by any name will not hurgt your p/s system.
imho
