engine noises - 2nd attempt
Old Sep 29, 2005 | 10:52 AM
02FX4Dude's Avatar
02FX4Dude
Hi All,
Apparently I didn't do something right on my first rebuild attempt 302, EFI. I have about 1500 miles on the engine, getting a tapping sound from the passenger side of the engine. it makes the tapping all the time-idle or driving, all rpm ranges. I looked for exhaust leaks, checked lifter preload, ran without the serpentine belt, and looked in the dark for arcing from plug wires. If I pull the plug wire off cylinder 3 the sound goes away.
So I've accepted that I need to pull the engine and start taking it apart. Any input what the cause is or what I should be looking for. As careful as I was with assembling, maybe I put a rod cap on backwards, I don't know. Should I pull ALL the piston/rod assemblies and take them to a machine shop to be checked/RR'd?
Thanks.
Old Sep 29, 2005 | 04:47 PM
ken75ranger's Avatar
ken75ranger
Before you pull the motor all the way out pull off the intake and check for a bad lifter. See if it's worn more than the others or if it's stuck. Did you change the valve covers or rockers? You might be hitting the valve cover.
Old Sep 29, 2005 | 07:51 PM
TigerDan's Avatar
TigerDan
When you built it, did you put in a new cam and lifters? If so, did you break them in correctly? It might possibly be a lobe on the cam that's gone flat, or a bad lifter as stated above.
I have seen a new cam and lifters not properly broken in have the base of the lifter chewed off by the cam, without hurting the cam any. Put in a new lifter and never had another problem with it.
Old Sep 30, 2005 | 07:13 AM
02FX4Dude's Avatar
02FX4Dude
A noisy lifter was the fisrt thing I though of, so I checked the lifter preload. Would the preload check ok if there was a bad lifter? While I had the covers off I ran the engine, the tapping was there, so it isn't a rocker-cover clearance problem.
Info I missed in first messsage: Everything is new except the block - cylinders where miked, still had visible crosshatch and where only honed to remove glaze, and was decked. The rods where reconditioned also, and new wrist pins installed with the new pistons.
I used plenty of cam lube, primed the oil pump, Motor was broken in by running 2000-2500 rpm for about 1/2 hr, changed oil, babied it for 500 miles, changed oil again. I did alot of reading here before the embarking on this adventure. I had some issues at first with misfire caused by incorrect spark gap, is it possible that damage something internal?
I think I will take that advice and pull the intake and get the lifters out and see how they look. Can I check the cam by using a dial indicator to check lift on the vavles?
Thanks for the help
Brian
