exhaust....
Old Sep 28, 2005 | 09:08 PM
buckshot047's Avatar
buckshot047
exhaust....
put the straight pipe on and that thing sounds pretty good...have a buddy that just spent alot of money on Magnaflow and personally I think mine sounds better now all I need is a big tip and should be good to go.
Old Sep 28, 2005 | 09:23 PM
AustinS's Avatar
AustinS
Right On! I know that my '01 sounded a lot cooler with the stock exhaust and the straight pipe. You should stand by the back while someone starts it. There's a couple second delay before you here the turbo wind up a little. Sounds cool as hell. If you plan on chipping it and other performance mods, get your gauges next. Then the prog/chip. Then get a new exhaust when the $$$ alows you to. I run the SCMT and when I went to the 4" from the stock, my egt's went down 200-300 degrees when pulling hard.
Meanwhile enjoy the new sound. I know I did even though the neighbors might have a different story.
Austin
p.s. get a polished stainless steel tip over chrome if you can... it gets hammered by debris back there.
