stumbling at idle
Old Jul 4, 2002 | 07:50 AM
tuffguy's Avatar
tuffguy
stumbling at idle
Gents,
I am at a loss. First the specs. I am running a 351M with the edlebrock performer package, MSD 6AL, Accel plugs, wires, and supercoil; stock type fuel pump. I recently tuned the motor. 15 deg initial timing.
Now my issue: I am on a road trip pulling a trailer from Kansas to Texas and then on to Washington, DC. At highway speed, she is running like a raped ape, but when at idle it is struggling to stay running. There is no smoke from the exhaust. I am at a loss. each cylinder is getting spark and I have checked all of the (very few) vaccuum connections and they are fine. Any ideas? I am on a severly time constrained schedule. thanks.
Old Jul 4, 2002 | 10:03 AM
wayne_j's Avatar
wayne_j
stumbling at idle
15* of advance at idle seems kind of high, 10* maybe 12 is all the higher I think one should go. Did you set it with the vacuum hose off? If you didn't then your true intial advance is way lower then you think.
Old Jul 4, 2002 | 10:26 AM
tuffguy's Avatar
tuffguy
stumbling at idle
I forgot to mention, the issue is intermitent. It has done it hot, cold, whatever. The other day it backfired in the carb and it has been doing it ever since.
Old Jul 4, 2002 | 11:22 AM
Mil1ion's Avatar
Mil1ion
stumbling at idle
Maybe it's from the change in altitude and your idle air/fuel screws need re-adjusting ?
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old Jul 4, 2002 | 11:55 AM
tuffguy's Avatar
tuffguy
stumbling at idle
Gents,
I think the problem is solved. It seams that after redoing the intake gasket and all of the other underhood work in prep for my 2000 mile trip I must have gotten some dirt in the carb or something. I then adjusted the carb to compensate. I also dropped in some carb cleaner in the tank. What I believe happened is that the stuff worked and the carb went back to normal with wacky adjustments. I just came in from retuning and it is back to normal.
Oh, any of you that doubt the 351M, I am on a road trip from Manhattan, KS to Granbury, TX on up to Washington, DC and when I wieghed my truck and load it came in at just under 9500lbs. I am pleased to say that with 35" tires and 3.50 gears I was able to cruise comfortably at 70-75 MPH and still get 11MPG. Yes, the truck is not stock and has lots of durability themed goods, but hey it kicks @$$!
Old Jul 4, 2002 | 09:34 PM
WrenchHead84's Avatar
WrenchHead84
Post stumbling at idle
Highboy727678
New Member Introductions
Sep 26, 2014 09:31 AM
puller45
Jun 20, 2013 04:07 AM
KrautBurner
Washington Chapter
120
Aug 2, 2011 02:58 PM
gtex
Texas Chapter
May 28, 2005 11:26 PM
Fordteamone
May 1, 2005 01:08 PM
