No Start....????
Old Sep 28, 2005 | 01:21 PM
JEV's Avatar
JEV
No Start....????
Here's the story. 1991 F-150-351. Pickup has been running just fine. Drove to work this morning with no problems. Went out at noon for lunch to go and get a bite to eat and she wouldn't start. Turns over fine. I can hear the fuel pumps start up. Checked for spark out of the distributor and the coil. Didn't have any spark. So, my question is, what could be wrong? I'm guessing it's either the coil or the ignition control module. Is there any quick way to narrow it down to one or the other? There are two wire in a harness that run to the coil. Correct me if I'm wrong, but is one always a hot 12volts and is the other pulsed from the ignition control? I'm just looking for a quick way to try and diagnose the problem and narrow it down before I have to pull it home.
Thanks,
JEV
Old Sep 28, 2005 | 02:35 PM
subford's Avatar
subford
If you can hear the fuel pumps run for more that two seconds while cranking then the PIP is OK from the Distributor. Yes the one side of the Coil (+ side) is HOT whenever the key is in the START or RUN Position and the other side does pulse. On you truck is the ignition control module mounted on the distributor or mounted remotely? You could try pulling out the SPOUT and see if it will start that way, it would be running at base timing. Do you have a test light with you?
Old Sep 28, 2005 | 02:53 PM
kenjan61's Avatar
kenjan61
I am going though the same situation. just figured out how to use my code reader and am getting a 211 and 212 code. 211 is profle ignition pickup (pip) sensor failure. 212 loss of ignition diagnostic monitor signal. stopped a the dealer and chatted with the service manager and he says the pcm needs to be replaced. $253.00 item, the worst part is ford is longer making it and it has to be replaced with an aftermarket one. the parts guysaid he needs the one out of the truck to order the replacement. it takes like three weeks to get. good luck with yours but the service guy said they have done alot of these recently.
Old Sep 28, 2005 | 02:56 PM
andym's Avatar
andym
I think your service guy is full of it. How does he know the PIP isn't bad? You can also get a PCM at the junkyard for probably $40.
One more reason to steer clear of a stealership.
Old Sep 28, 2005 | 03:03 PM
JEV's Avatar
JEV
The ICM is located on the distributor. I'm going to do a little more checking on it during my break....
JEV
Old Sep 28, 2005 | 03:04 PM
kenjan61's Avatar
kenjan61
already replaced the pip, dist cap, rotor, coil, ignition module and ignition swtich. he also said they need the old pcm to match to the new with the vin number for proper control
Old Sep 28, 2005 | 03:06 PM
kenjan61's Avatar
kenjan61
the icm is bolted to a heat sink which is bolted to the fender on the left side just below the hinge spring on my 95 f250
Old Sep 28, 2005 | 03:08 PM
kenjan61's Avatar
kenjan61
Parts . OEM Part
. Price
Engine Control Module
. ECM . F5TZ12A650ALA
. $258.60
Notes
Labor . Skill
Level
. Warr.
. Std.
. Replace . A
. 1.1
. 1.5
Notes
. . Includes: Pin Point Test.
Copyright © 2005 ALLDATA LLC
Terms of Use
Old Sep 28, 2005 | 03:16 PM
subford's Avatar
subford
I would say that the PIP sensor codes mean that the PCM missed seeing a PIP ever now and then. If you lose the PIP pulse completely the PCM turns off the fuel pumps to kill the engine. You would lose the spark also.
I also think andym knows what he is talking about.
Old Sep 28, 2005 | 03:28 PM
subford's Avatar
subford
I do not know why the ignition swtich was changed but other items can cause arcing including the plug wires and will give these codes (211 & 212).
Also a bad pins, and corrosion at the PCM plug will also give these codes.
Old Sep 29, 2005 | 09:57 AM
JEV's Avatar
JEV
Turned out to be the Ignition control module. Put the new one in and she fired right up...
JEV
Old Sep 29, 2005 | 05:18 PM
kenjan61's Avatar
kenjan61
disconnected all plug in connections, blew tem out with air, plugged them all back and no codes came back. maybe i got it.
