Differential Gear Oil
Old Sep 28, 2005 | 10:51 AM
Saguaro_7.3's Avatar
Saguaro_7.3
Red face Differential Gear Oil
Still trying to find out what weight gear oil to use when I change the fluid in the differentials - also in the transfer case. Any info would be appreciated.
Old Sep 28, 2005 | 04:50 PM
slc10844's Avatar
slc10844
The front should be 80w-90 gear lube and the rear 75w-140 synthetic. If you have a notion, you could run syntheic in both.
Old Sep 28, 2005 | 05:27 PM
WA.Ranger's Avatar
WA.Ranger
Deffinatly run synthetic in the rear!, transfer case is ATF in mine.
Old Sep 28, 2005 | 07:48 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yeah if you have added power any where starting from the bumper back (looking on top of the truck), you would benefit from cooler temperatures/less friction and longer service life by upgrading to synthetic. as i change mine, it will go to synthetic. kwikkordead uses Redline 75W-140 in his, he praises it.
