dieseling backwards & starting problems
Old Sep 28, 2005 | 09:02 AM
OSin86's Avatar
OSin86
2 questions:
1) When I go to start the truck it rarely will start as the starter is turning. In order for it to pop I have to let off the starter and see if she wants to run. If it does run it pops immediately after I stop turning the starter. Any ideas?
2) When I turn the engine off it likes to start running backwards in almost a dieing style chug. I always have it in gear and the clutch ready to stop it. Any ideas?
Besides starting and turning it off the motor runs, idles and pulls great. Thanks for any help.
Old Sep 28, 2005 | 09:29 AM
Sycostang67's Avatar
Sycostang67
Could be several things, dieseling is usually caused by incorrect timing, fuel mixture, or carbon deposits(hot spots) in the combustion chambers. In order to get my old 79 F-150 to pass smog, I would swap a smaller carb on and lean it out, which would cause it to diesel when shut off.
Old Sep 28, 2005 | 10:37 AM
fordborn's Avatar
fordborn
Definitely check the timing, I have seen these do this before and found the timing is way off, usually retarded to much.
Old Oct 6, 2005 | 11:07 AM
OSin86's Avatar
OSin86
Sorry for slow responce guys but it was the timing. Thanks a lot for the help!
