Every once in a while, my '79 F350 Camper Special will refuse to start. As long as the starter is engaged, it will run (generally a short VROOOOM). Once the key is put back to the run position, it dies. Leave it set for a while, and it will start right up. Also, I've been going down the road and it will die. Trying to start it and it's just like what I've already described...... short VROOOOM's. Leave it set a few minutes, and I'm off again. This only happens occasionally, it's by no means a regular occurance.
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page. JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
The ignition module has a 'start' and 'run' lead. Your 'start' works all the time. The run works most of the time. Therefore...... Ignition module or intermitant wiring/switch/connectors to module would be the most likely candidate. GL
I had the same problem on a truck I owned about a year and a half ago. Thought for sure it was the ignition module but it ended up only being a bad wire between the coil and the distributor cap.
