Door Tag numbers
Old Sep 27, 2005 | 07:19 PM
royale5's Avatar
royale5
Door Tag numbers
I know I saw a thread on what the numbers on the door tag means. Anyone know where it is or how to read it?? THANKS
Old Sep 27, 2005 | 07:32 PM
andym's Avatar
andym
Your owner's manual is the place to decode the information there. If you don't have one, post back here with specific questions, and someone will answer them - or you can search for them.
Old Sep 27, 2005 | 07:40 PM
Jack01's Avatar
Jack01
The door tag is the vehicle (truck Safety compliance certification label..along with what your vehicle came equiped from the factory with as that there are several models or variants of the F 150,250,350
you can find information regarding axle code, tranny code, engine code, paint codes, and springs, along with type of smog equipment,body style, engine type, calibration data for egr and gross weight and tow cap
Old Sep 27, 2005 | 07:55 PM
95X15's Avatar
95X15
Try this - it's under articles specs at top of screen.
https://www.ford-trucks.com/article/...r_Decoder.html
Old Sep 27, 2005 | 08:04 PM
royale5's Avatar
royale5
Thanks that is what I was looking for. But it doesn't have my Axle code on the list. anyone know what my gears are by this tag??? Thanks
Old Sep 27, 2005 | 08:05 PM
royale5's Avatar
royale5
I just found it, so I have 3.31 gears. I have found that it feels somewhat week when towing. What could I jump up to to get more out of the truck??
Old Sep 28, 2005 | 08:15 AM
subford's Avatar
subford
I have a 302 and 4R70W Transmission in a '95 also, you could go to 3.55:1 and that would give a little more power. This what I was going to be changing to before the gas prices went up but now I will stay with the 3.31:1 and just make it LS.
Old Sep 28, 2005 | 08:21 AM
royale5's Avatar
royale5
The truck is not my daily driver so I am not too concerned with mileage. I just want to be able to tow w/o straining the truck. Are 3.55 1 step up? What would be the next up from 3.55?
Old Sep 28, 2005 | 09:16 AM
subford's Avatar
subford
After 3.55:1 the next would be 4.10:1.
With 4.10:1 the engine will wrap up fast and you top speed will be down but you can pull a lot more. Might want to put on some more spring also.
Old Sep 28, 2005 | 09:35 AM
royale5's Avatar
royale5
I think I may go with the 3.55, what do you meen by put on some more spring?? Sorry for the noob questions.
Old Sep 28, 2005 | 09:58 AM
subford's Avatar
subford
I was just thinking that with a 4.10:1 and if tried to pull out a stump, load it down or something it might snap the standard springs.
Old Sep 28, 2005 | 11:44 AM
andym's Avatar
andym
If you're putting so much weight in a truck that you're worried about breaking the springs, then you need a bigger truck. Overloading a vehicle to that point is not safe and can get you into a lot of legal trouble, especially if you're involved in an accident.
Going from 3.31 to 3.55 will not net you much at all. Going to 4.10's will be much more noticable. Since you're going to be paying $500 per axle for the change, I would advise not spending the money unless it's going to make a significant difference.
Old Sep 28, 2005 | 01:39 PM
jscarb2's Avatar
jscarb2
there should also be the 3.73:1 option if i am not mistaken
Old Sep 28, 2005 | 02:18 PM
subford's Avatar
subford
I though that the 3.73:1 was a 1997 or newer axle, that is why I did not say anything about it. It was not listed in the 1995 shop manual. The 1997 and newer had different wheel and pad spacing.
I have vehicles running 9" 3.25:1 LS, 8.8" 3.31:1, 3.55:1 LS and Dana 4.10:1, they are all in 150's except the 4.10:1 and they are in a 250 & a 350.
