96 explorer where's the DPFE sensor located?
Old Sep 27, 2005 | 12:48 AM
stoad's Avatar
stoad
I'm not much of a gear head, but I hold my own keeping the house & vehicles together. I believe I need to replace the DPFE sensor, and possibly the EGR valve, on a 96 v-8 explorer (CEL w/ "EGR flow insufficient"). I picked up the replacement sensors (the DPFE is the metal version), but I can't find them under the hood to save my life... any help in locating these buggers would be appreciated. thanks.
Old Sep 27, 2005 | 09:38 PM
CanadaGuy's Avatar
CanadaGuy
I believe it's stuffed in the back behind the intake on the passenger side.
Old Sep 27, 2005 | 11:16 PM
CobraXP's Avatar
CobraXP
There is not a DPFE sensor on the 96 and early 97 model V8's. Only thing you have is the EGR valve on the back of the intake elbow behind the throttle body.
Old Sep 28, 2005 | 12:09 AM
ynot2244's Avatar
ynot2244
I agree with David. I have a 1997 5.0L and there is no DPFE. Believe me I looked for hours, dealer finially told me there isn't one. Check your EGR valve with a hand vacuum pump while engine at idle. If the valve opens the engine should almost stall at idle. If it doesn't run rough the valve is not opening. At this point replace the EGR valve.
Good luck
Old Sep 28, 2005 | 09:33 AM
stoad's Avatar
stoad
thanks, guys, I'd already spent hours searching for it. Glad I'm not a complete nimrod (still a partial probably). I'll get my $60 back & start focusing on the EGR valve. Any thoughts on other causes for CEL code P0401?
Old Sep 28, 2005 | 04:57 PM
CanadaGuy's Avatar
CanadaGuy
There should be an EGR postion sensor on top of the EGR valve.
