Sponsored by: Auxito
98 back up lights
Old Sep 26, 2005 | 10:01 PM
rickerrr2002's Avatar
rickerrr2002
98 back up lights
confused here! 98 f-150 has no back up lights, checked fuses..ok.....replaced transmission control switch wich is supposed to control back up lights and still nothing...and then noticed cruise control and ac wont work now?????? is there another switch that controlls back up lights?????
Old Sep 27, 2005 | 05:15 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 27, 2005 | 09:17 AM
lancekilgore's Avatar
lancekilgore
Recheck all the fuses even the ones in the or under the hood. there is probably another fuse the runs it all. also be carefull to verify the fuses in question are good. The link in the fuse does not always blow in the middle sometimes it on the side just a check. are you getting power to the back up switch at the tranny. should be easy enough to run a jumper wire if there is power and if the lights don't come on then it is between the switch and back up lights. I would recheck the fuses first.
Lance
Old Sep 27, 2005 | 07:29 PM
rickerrr2002
Smile 98 back up lights
problem solved today...........fuses were fine....the fuses were practically falling out of the fuse block by themselves when i went to pull them out, ( i checked the fuses before while they were installed with a meter and they showed good) the fuses were not making good contact so i used needle nosed pliers and bent the fuse ends just a little so they would fit snug!!!!!! my buddy had the same problem with a fuse in his 98 f-150, after a few years they would not fit snug any more??????? thanks guys for your suggestions.
Old Sep 27, 2005 | 08:20 PM
Racerguy's Avatar
Racerguy
Thanks for letting us know what fixed it
