Sponsored by: Real Truck
Newbie question about tires.
Old Sep 26, 2005 | 06:37 PM
JB666Rock's Avatar
JB666Rock
Ok, the 2001 F250SD I just bought is in need of tires. It's only got 40k on it, but they've got some dry-rot.
It's got 235/85/16's on it right now, and I want to keep the stock wheels.
What size can I go up to without the tires bulging off the rim?? Will a 285 fit??
Thanks, in advance. I know these questions are irritating, but I've been dying to know.
Old Sep 26, 2005 | 06:58 PM
Steve_250's Avatar
Steve_250
To some, the 295's are questionable while others say they are the max. It has been said that some shops won't put 295's on that rim while others will. They stick out past the rim a bit more. With the 285's you'll be fine.
BFG A/T seems like a good choice, not noisy and good on the mud & snow.
Not a real soft or hard tire.
I have stock 265's on mine but will upgrade to a wider rim and a 4" lift for 315's.
Personally, I'm going to err on the side of safety.
Old Sep 26, 2005 | 07:01 PM
JB666Rock's Avatar
JB666Rock
Thanks - You actually gave me the answer I was looking for - I was hoping a set of 285's would fit on the stock rims. I love the looks of the BFG AT.
Old Sep 26, 2005 | 07:13 PM
boxcar1974's Avatar
boxcar1974
I have put close to 35K on my 285 bridgestone revo's. I have had not fitment or wear issues at all. 285's will be just fine.
Old Sep 26, 2005 | 07:16 PM
JB666Rock's Avatar
JB666Rock
Stupid question, but do you have any pictures of the truck with these tires??
Old Sep 26, 2005 | 07:33 PM
boxcar1974's Avatar
boxcar1974
Look in my gallery. I have some before and after pics.
Old Sep 26, 2005 | 07:38 PM
JB666Rock's Avatar
JB666Rock
Looks great! Thanks for the pictures
Old Sep 26, 2005 | 09:18 PM
3/4ER's Avatar
3/4ER
What is the width of your stock rims? The 265/75-16E comes on a 7 inch rim.
Old Sep 26, 2005 | 09:20 PM
JB666Rock's Avatar
JB666Rock
I believe my stock rims are 7". I've been reading about a lot of guys running 285's without a problem, even though they aren't recommended.
Old Sep 27, 2005 | 03:14 AM
FortyFords's Avatar
FortyFords
My first question would be what gear ratio do you have ? if its 3.73 stay with 265's
any bigger tire will change the truck to a dog for pulling things and fuel mpg's go down
Now if you have 4.10's or lower have at it
Just my $.02
Rich
Old Sep 27, 2005 | 06:08 AM
JB666Rock's Avatar
JB666Rock
Hi Rich - It's got the 4.10's
Old Sep 27, 2005 | 12:27 PM
DeerSniper's Avatar
DeerSniper
285s are fine with 3.73s.
Old Sep 27, 2005 | 02:05 PM
FortyFords's Avatar
FortyFords
deersniper
not if you tow alot makes the tranny hunt alot,also drops the rpms out of the powerband too much.lugging the engine is not good for the valve train in the engine.
Yes ,you can put them on I agree but it changes the responsiveness of the truck.
IMHO
Rich
Old Sep 27, 2005 | 02:24 PM
Kenworth's Avatar
Kenworth
You do have to watch trying to run a wider tire on a rim not designed for it is the center of the tire wears out quicker. Also you have to watch out for if you hit a pot hole to hard you run the risk of blowing the bead.
If you want a bigger tire get the proper width rim to match it tire manufactures do say what width you need for a reason. If you are looking for a taller tire have you considered 255/85R16s. You are doing the right thing by getting rid of tires that have checked sidewalls they are dangerous.
I imagine the truck is still running the stock Firestones which are crap anyhow the wear good but thats about it they handle like crap.
Old Sep 27, 2005 | 06:08 PM
mattsf250's Avatar
mattsf250
315/75/16
no buldge.........ok, a little.
