I'm going through stuff on my '86 F-150 this week. Had this truck since new. 5.0L FI, 4 speed. Retired contractor. This was the best of three that I had, so I kept it. Now up to 140K, with lots of life left.
So, I have a dead temp gauge, maybe. I assume that if I put 12V on it directly, off the truck, the needle should pin. What happens, is that it slowly moves to the upper end of normal range, and stops. Is there some kind of buffer on the gauge, or is it bad? It is dead on the truck, so the sensor may be fried as well. The wiring is good.
Quick, simple test. Remove the wire from the sending unit & ground it to the engine, have someone turn the key to run, if the gauge pegs at full hot, replace the sending unit.
Theres 2 temp sending units the temp gauge sending unit has a single wire.
I do not know how you put 12V on it. It is mounted on a PC board and feed is from the Instrument Voltage Regulator (IVR) on one side and the other side has a variable resistor to ground. If you somehow put 12VDC on the IVR side it would read higher and if you put it on the other side it would read zero. Pull the wire ( R/W 39) off the Temp Sender, turn the key on and see what it says. Then short the wire ( R/W 39) to ground and see what the Gage says. If the Gage moves peg to peg in this test the gage is good.
I your Gas and Oil Pressure Gage work OK then your IVR is OK and since your Gage moved I would think it to be OK too. Make sure you coolant is full and if it still reads low replace the Temp. Sender.
I know the difference between the temp sender on the block (single wire), and the one on the t-stat housing (2-wire). The gauge failed the "short to ground test". That was the first thing I tried. Not convinced that the wiring was good, I pulled out the instrument cluster. (Needed to replace a bunch of lamps anyway). Temp gauge or sensors have failed on every Ford truck I've ever had, and that's more trucks than I can remember! Usually the sensor, but frequently the wire shorts out or breaks. I checked continuity of the lead. Good. So, I bench tested the cluster, applying 12 V to the lead on the circuit board. That gave me gauge motion, but didn't peg it. At this point, I'll probably change the temp sensor on principle, but I'd rather not put the cluster back in and find the gauge still doesn't work. Everything else on the dash works fine.
TIA for the help.
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
No. The guage is fed voltage anytime the key is on through the instrument cluster. The wire going to the sending unit should be grounded or left in the air touching nothing. Grounding the wire should swing the guage full scale in one direction, and taking the wire off and letting it hang in the air should make it swing full scale the opposite direction.
If you put a voltmeter on the sending unit wire, you should see the meter flicker up and down. This is the chopped up voltage coming from the IVR.
