question on waterpump swap
Old Sep 26, 2005 | 01:05 PM
h-m's Avatar
h-m
Hi guys,
I am replacing the motor from my dead '92 f150 5.0L with a good 1980 302 that is good. It came to me with the frontcover and waterpump on it already. the waterpump is reported to be maybe a donor, so i was going to throw my almost new '92 pump on here. It seems that this one on the '80 has some differnent bolts on it. The outlets are in the same spots, but the '80 has 3 bolts going on the lower side of the shaft, that are not on the '92 waterpump. My question is, will this pump work with my serpentine belt or should i pull my front cover and throw my '92 cover and pump on this old block?
thanks much, guys.
Old Sep 26, 2005 | 02:52 PM
rebocardo's Avatar
rebocardo
Won't the water pump for the 1992 5.0 be turning the wrong way on the 1980 302?
Old Sep 26, 2005 | 02:59 PM
h-m's Avatar
h-m
thats what i am afraid of
I am putting this '80 block in my '92 f150, with the serpentine belt, so i am afraid that the old pre-'80 pump might be made to turn the other way from what my '92 spins.
thanks guys. Hope someone can answer that for sure.
thanks
Old Sep 27, 2005 | 08:37 AM
h-m's Avatar
h-m
yep it does turn wrong way
i pulled the waterpump on both lastnight and yes the old one does turn the wrong way for the serpentine belt.
thanks guys.
micheal
