Another 351W rebuild.......
Old Sep 27, 2005 | 02:44 PM
MustangGT221's Avatar
MustangGT221
I saw an article on another forum about cast/aluminum heads. Some magazine took the same motor, same everything, and did a comparo test between the cast and aluminum heads. It was on a chevy, but they got cast and aluminum heads that flowed as identical numbers as possible, and kept everything the same as much as possible. The power difference was less then 5 hp...
I would not consider cast or aluminum based on power, I would based on the aluminum's heat distribution and weight savings.
Old Sep 27, 2005 | 02:58 PM
Tripower455's Avatar
Tripower455
Actually, I am only considering them because there are a lot more good flowing choices available than iron heads, and I can comfortably get another point of CR, which is an issue with most of the easily available pistons. I don't want much over 9.5:1 with iron and 10:1 with aluminum. I know with the Pontiacs, by the time you pay someone to port a set of iron heads, you can just about buy a set of aluminum heads that flow as well, right out of the box, with more room for improvement. If I could get the stockers to flow over 200-220 cfm for around $500 including a valve/guide job and surfacing, I'd be happy. I am not too optimistic on that though.... It seems that $1k will give me a decent choice of complete aftermarket heads for the Ford.....
I don't care about the weight at all.... it's a truck ....
It appears that price/performance wise, I am ahead of the game with a set of aluminum heads over ported stockers. Unless I am missing something.
Are there any reputable guys selling decently ported/flowing stockers for a reasonable price? I do not want to pay a local guy to port them, as you never know what you're gonna get. Heck, I won't even let any of them touch a pontiac head.......
Personally, I am not a huge fan of aluminum heads on an iron block that is more or less a daily driver.
Old Sep 27, 2005 | 07:57 PM
MustangGT221
Aluminum heads on an iron block are perfectly fine, you just need the right head gasket.
10:1 compression with aluminum heads, probably has 93 octane written on it.
I didn't care too much about the weight either, but after swapping in a ZF and 351 based engine over my previous 302/M5OD combo, I lost about 3/4"-1" in my front suspension from the extra weight. My tires rub too often now
Old Sep 27, 2005 | 09:04 PM
Tripower455
Mine came stock with a ZF, iron heads and a 4600 lb front axle. As I said, I'm not worried in the least about the weight .
I don't like aluminum heads on cast iron blocks, because of the different expansion properties of the two metals. Normally, it's fine, but if you have the same material for both block and head, in an overheat situation, it is less likely to blow a head gasket than with different metals. Not a problem, just less margin for error.
If I had my choice, I'd use a set of stock iron heads if I can get them to flow adequately for my setup.
I agree about the 93 octane, which is why I asked about the dished pistons. I've been through this a bunch of times on other motors, and always come to the same conclusion. Limiting CR is the only way to run pump gas on a regular basis. Everything else is alchemy with varying results. I'll run up to the high 9's on 93 with iron heads. Aluminum, you can probably get away with 89 and MAYBE 87 with proper tuning at the same CR. Over 10 it gets harder. I'd like it under 9:1.....
Fortunately, there are a lot of choices in dished pistons for the Ford.
I'll get it figured out......
Old Sep 27, 2005 | 09:25 PM
MustangGT221
With a $6000+ engine, you bet your butt my eye is watchin' that temp gauge. It wouldn't be overheating without me knowing it, or atleast I hope so.
I duno if I'd let that sway your decision, thats all...many many people run aluminium heads on these motors. It's mostly what's available.
Ya, lots of parts for a Ford motor. You shouldn't really have a problem keeping that compression down enough to run lower gas...but remember...93 really isn't that much more money than 87. Depending on your mileage, under $200 a year.
Old Sep 27, 2005 | 09:41 PM
Tripower455
I've been running 93 in my daily drivers (10:1+ LS1s) for the last 5 years, but if I had my druthers, in the truck, I'd rather take a slight hit in power to run the cheap stuff.
As for the aluminum heads, I am not ruling them out, I just don't think they are a priority for this build unless I can't build a decent set of iron ones. It's basically a tow truck after all!
Old Sep 28, 2005 | 05:24 PM
MustangGT221
Sounds good
Old Oct 2, 2005 | 11:21 AM
Tripower455
Well, I decided on a 393 (scat crank, -30cc dished forged pistons, eagle forged rods), with a set of ProComp 60cc aluminum heads. It will run 8.5:1 without milling, and should be a nice torque upgrade from the 351.
Thanks for your help guys!
I'll post more info as the build progresses.....
Old Oct 2, 2005 | 11:56 AM
MustangGT221
Have ya had time to research the heads yet? I'd like to learn more about some of that...
Old Oct 2, 2005 | 12:00 PM
Tripower455
From what I've read, they're basically copies of the Victor Jrs. The price is certainly right, so I am going to give them a try. I haven't oredered them yet, and will do some more research before purchasing, but they should work.....
I figure that some of the Mustang forums ought to have some info on them....
Old Oct 2, 2005 | 03:02 PM
PyroBob's Avatar
PyroBob
Blast, I missed chiming in by a day.
I had completely designed a 393 for my truck on my dyno software, while looking for the best possible torque output.
I peaked at 460 lb/ft from 3000-3500 rpm, and my hp at 320 @ 4500.
Obviously, these are mathematical, and may not be achieved, but the idea was a strong reliable stroker, with efi, that didnt break my bank.
I used the flow data for World Products Roush 200 (windsor sr.) heads, a 3.85" stroke, a 4.03" bore, and a Comp Cam # 35-231-3. The intake was a trick flow, and the exhaust was long tube headers with mufflers.
The head flow data (along with a lot of other head flow data) is here:
hxxp://users.erols.com/srweiss/tablehdc.htm#Ford
And the cam data is here:
hxxp://www.compcams.com/Technical/Search/CamDetails.asp?PartNumber=35-231-3
I probably did plan on spending more overall then you are looking to spend, around 6K w/ all the machine work. Nonetheless, I hope your build goes good, as I get to use instances like Justin's to know what not to do
Old Oct 2, 2005 | 04:48 PM
MustangGT221
Unfortunately, for me...
