Hello everyone, I'm new to this site and have read a lot and found some really good info. I wanted to know if anyone knows where to get a good 400 crank for my 351m. Any advice is appreciated.
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
i'm going to to need one also and i found a hole crank kit at advanced auto for $190+tax. thats a good deal for a .010-.010 crank, bearings and a warranty. hope this you out.
Thanks for the info, hopefully at tax time I can have everything done to the engine to prepare for the upgrade. In the meantime I'm adding an intake, carb, cam and lifters, new valve springs, and thinking about going noisy gear drive, any thoughts on that.
The only thing that you will get out of a noisy gear drive is noise. A good double roller chain set will last as long as you need it. Find some other place to spend your money.
agreed. i went in to experiment with the advance/retard keyways after about 500 miles. the double roller chain was totally wrenched out, flopping like it had over 50k on it. i'm running a quiet gear now, kinda wish i got the noisy? one thing for sure though, it hasn't stretched one tiny bit.
